Hi, I’m using audacity-win-2.1.2.exe on windows XP pro.
I would like to use Audacity to recored old tapes and would like to set a time limit for Audacity’s recording, so it doesn’t go on all night.
Is this possible in an easy way ?
thanks
thanks
I presume that you are aware of the security risks in using XP?
There’s the “Timer Record” feature: http://manual.audacityteam.org/man/timer_record.html
This feature has been substantially improved in Audacity 2.1.3 which is due to be released in the next week or so.
well, it’s just an old laptop not connected to the Internet, so I don’t worry…
Ok, can you give me a scoop on the new features ?
Thanks
Here’s a Windows 10 screenshot of the the 2.1.3 Timer Record interface:
