This is a very minor problem but it’s kinda frustrating especially when dealing with audio loops, the selection tool doesn’t automatically snap to the end of an audio piece when i select it
I’ve tried reinstalling and redefining preferences but it doesn’t seem to work, and this problem only occurs with one project, which has 7 tracks and is about 7 minutes long
Are you referring to the vertical yellow snap line that appears when you drag a selection to the time position of a clip boundary or label?
What exactly are you doing when the problem occurs?
Thank you for answering, yes i am referring to that, now that the yellow snap line doesn’t show up i have to manually zoom a lot to select the exact end of a clip
I can’t tell you exactly what triggered it, i’m not sure but i think i saw the problem after i added the 5th track and was editing it (cutting and moving), but that was when i realized it
Also today i recorded another track for the project and when i drag it across the screen It only snaps where it’s highlighted
If “Snap To” in Selection Toolbar is enabled, mouse-dragged selections and mouse clicks will only snap to the chosen unit of time and not to physical boundaries (unless a boundary is already aligned with the chosen unit of time).
Using a similar layout to that you show, I could not reproduce the problem in 2.1.3 or 2.2.0-alpha.
Please save it as a project and attach the AUP file so we can see exact timings of the labels and audio tracks. Please see how to attach files to forum posts.
