How would I be able to select as-per splitted sections within a track-layer
according to Beginning (A) / End (B)? Understand that the track has multiple splitted sections within the track-layer, all of which are similar in length.
Rather than having the splitted-regions be put onto another track; instead, i’m
speaking on behalf of having those splitted-regions (the in-between’s) be
selected (I understand this can only be done, if it’s been processed by using labeled audio).
What do you want to do to the labeled audio?
So, I want to be able to have each splitted-regions be selected. In my example
we’re talking about more-than-1-by-a-bunch.
There is no multiple select of separate regions except using Labeled Audio.
Hmm, in this-case I do have the regions made-split via Labeled-Audio. How
would I then be able to select Them All?
Labeled Audio works on the audio of all labels that are encompassed by the selection you make in the Label Track. The selection remains the same after processing.
It would probably help if you said what you are trying to do. If you could select all the labels at once, which you can’t, what would you want to do to those regions?
