Select start/end by pausing playback?
Is there a way to mark the start or end of a selection precisely where I pause during playback?
(If not, consider this a Feature Request for v4.)
In Audacity 3, the shortcuts are “[” and “]” .
Another option is to create a label at the paused position using Cmd/Ctrl-B.
In Audacity 4 the “[” and “]” shortcuts exist but by my quick testing they don’t appear to work as intended.
According to the new AU4 manual, they are working as intended. I think they’re useless as implemented.
There was a feature called Store Cursor Position
