I have the last audacity version installed.
I need to locate a portion of audio and extract to a new file. In mp3 or similar.
How can I navigate easily ?
Can I mark the audio in portions forever ?
Best Regards
Best Regards
Not forever, no. Audacity doesn’t have edit marks. Audacity does have labels. You can zoom into the show…
https://manual.audacityteam.org/man/zooming.html
… and set a label…
https://manual.audacityteam.org/man/label_tracks.html
…at the beginning and the end points. The labels are sticky and will make your cursor stick to them when you drag over the selection. File > Export > Export Selected Audio.
Have you ever made an MP3 file? You have to download and install the LAME software package to do that.
(scroll down)
https://www.audacityteam.org/download/windows/
Thanks a lot. A good part of my difficulties with audacity concerns my particular way of the user interacts. I will try to adapt to the standard.
I will revise these tutorials.
Best Regards
