Hello,
I installed Scarlett plug-in suite on my pc. (I just bought a Scarlett 2i2 to record my voice) Can I use these plug-ins with Audacity and if so, how?
Sorry I’m a beginner…
Hello,
You will have to install the VST versions of the plug-ins on Windows. They should work in Audacity as long as they don’t rely on changing audio as it plays.
To install VST effects in Audacity, see this page in the Manual: http://manual.audacityteam.org/o/man/effect_menu.html#VST_Effects .
Audacity doesn’t do anything in real time, so don’t fall in love with pre-filtering your voice. Everything is post production.
Okay, I installed it. But now how does ik work?? Where can I find it now in Audacity?
Did you tell Audacity to rescan for VST effects?
(see this FAQ for details: http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#vst_install)
Yes I did. But I still don’t know how to continue…
How to continue with what? If you have rescanned and restarted Audacity, did you enable the plug-ins in “Install VST Effects” when it appeared?
If the plug-ins are underneath the divider (towards the bottom) in the Effect Menu, that’s all we need to know.
It’s up to you how you use the effects (if they are usable). You select some or all the audio then run the effect on the selection. For help using the effects, try clicking the link in blue to read the plug-in manual: Scarlett Plug-ins Suite manual .
