Hi , first time poster. I’m on windows 7 64 bit.
Can anyone tell me how to go about exporting audio from my ipad 2 running Sampletank free app to Audacity v 2.1.2.
Regards
Not sure what you mean.
Do you have some audio files made with “Sampletank free app” on you Win 7 PC?
If that’s the case:
Are you able to play those files on your PC?
What format are those files?
Hi Steve , thanks for the reply.
I have Sampletank Free on my ipad2 , I wish to export the audio files to Audacity running on my PC.
Regards
First you will need to get the audio files onto your PC. We don’t make Sampletank and I don’t have an ipad2 so I have no idea how you would do that, or even in it is possible - try checking to manual for Sampletank Free, or ask on their forum / support channel to find out: (a) if it can be done, (b) how to do it, (c) what format the audio files will be once you get them onto your PC. When you have that information, then we can help you with using Audacity.
