03:50:50: Audacity 3.0.0
03:50:50: Trying to load FFmpeg libraries...
03:50:50: Trying to load FFmpeg libraries from default path, 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
03:50:50: Looking up PATH environment variable...
03:50:50: PATH = 'C:\Program Files (x86)\Razer Chroma SDK\bin;C:\Program Files\Razer Chroma SDK\bin;C:\Program Files (x86)\Razer\ChromaBroadcast\bin;C:\Program Files\Razer\ChromaBroadcast\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\GtkSharp\2.12\bin;C:\Program Files (x86)\QuickTime\QTSystem\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;C:\Users\Skelecool\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\JetBrains\IntelliJ IDEA Community Edition 2020.1\bin;'
03:50:50: Temporarily prepending ';C:\Program Files (x86)\FFmpeg for Audacity' to PATH...
03:50:50: Checking for monolithic avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
03:50:50: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
03:50:50: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
03:50:50: avformat not monolithic
03:50:50: Loading avutil from 'avutil-52.dll'.
03:50:50: Loading avcodec from 'avcodec-55.dll'.
03:50:50: Loading avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
03:50:50: Actual avutil path C:\Program Files (x86)\FFmpeg for Audacity\avutil-52.dll
03:50:50: Actual avcodec path C:\Program Files (x86)\FFmpeg for Audacity\avcodec-55.dll
03:50:50: Actual avformat path C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
03:50:50: Importing symbols...
03:50:50: All symbols loaded successfully. Initializing the library.
03:50:50: Retrieving FFmpeg library version numbers:
03:50:50: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
03:50:50: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
03:50:50: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
03:50:50: Returning PATH to previous setting: C:\Program Files (x86)\Razer Chroma SDK\bin;C:\Program Files\Razer Chroma SDK\bin;C:\Program Files (x86)\Razer\ChromaBroadcast\bin;C:\Program Files\Razer\ChromaBroadcast\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\GtkSharp\2.12\bin;C:\Program Files (x86)\QuickTime\QTSystem\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;C:\Users\Skelecool\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\JetBrains\IntelliJ IDEA Community Edition 2020.1\bin;
03:50:50: FFmpeg libraries loaded successfully.
I tried using the RoVee plugin in audacity today and whenever I press apply or try to listen to it it crashes almost immediately, the resulting crash log is above.
