Hi, one thing I miss a lot in the rhythm track option is that you can’t create complex time signatures with it.
You can set 7 beats per measure, but it’s always strong beat and then the rest weak beats. In example, in times signatures like 5/4, the beats go strong weak weak strong weak, or strong weak strong weak weak. That would be like joining 3/4 + 2/4 or 2/4 + 3/4.
There are more complex situations, for example you can have a really weird 9/8 piece that goes like this:
1 2, 1 2, 1 2, 1 2 3 (notice this are 9 beats in total, and its structure is like a 4/4 but with an extra beat in the 4th beat) [this is done x3 times]
1 2 3, 1 2 3, 1 2 3 (and the 4th time you do it like a 3/4 structure, knowing it’s a 9/8 and you must have 3 beats per “regular” 3/4 beats)
then you repeat that all the time, so the 9/8 is like divided in 4 different things, although the first 3 are identical.
In other words, there should be an option in that menu to let us select where the strong beats lie, and also a way to be able to create the weird 9/8 I just explained. I’m quite sure if you add a way to create that, no time signature will be left out.
Thanks, if you have any doubts, I’m here!
