Is it possible to find the script lines in the Gverb Dll so that I can save my preferred settings? It is so time-consuming to have to re-enter my settings each time the program is opened. I see the line more than halfway down that starts with "Tail level (dB) Early reflection level (dB) Dry signal level (dB) , etc, but there is no way to edit the defaults (no numbers appear. The controls on the Gverb app are changed by sliders. I’m using Windows 10 Home.
Which version of Audacity are you using? GVerb was replaced by a better reverb effect many years ago.
The current version of Audacity is 2.4.2 and it is available via the Audacity website: https://www.audacityteam.org/download/windows/
Like other plug-ins, you can save presets …
