When i try to select a sound slice from a graphical block on the screen it takes too long to stay in the music. I have to wait like 10 secs for the next action and if lock tracks feature is on it takes like forever. It blocks the flow and only 20 pct of cpu is being used dosnt make sense. Please is there a solution on its way to this?
Are you working with very long recordings?
Does your computer have multiple CPU cores?
Do you have a lot of labels in the project?
If you are selecting using the keyboard, select using the mouse instead.
Keyboard selection in long projects should be improved in the next 2.0.6 when released.
