neok
April 16, 2019, 4:27pm
1
Here’s what I’d like to do:
Open soundclip1.wav
Pitch shift the audio (not touching the duration), and export it as soundclip2.wav (and 3,4,etc.)
Re-open soundclip1.wav, split and isolate a bunch of segments, and save the project
Export the clips (via Export Multiple)
REPLACE soundclip1.wav with soundclip2.wav, basically using the new audio source but keeping my current clip selections
Export the same clips but with the new, pitch-shifted audio
Is step #5 possible? Can you replace the base audio, keeping the clip timing intact?
April 16, 2019, 5:16pm
2
No, but you could add a label track, and label each clip, then after you’ve replaced the audio track, split it based on the labels.
See these pages of the manual:
https://manual.audacityteam.org/man/label_tracks.html
and
https://manual.audacityteam.org/man/edit_menu_labeled_audio.html
neok
April 16, 2019, 5:33pm
3
Thanks for the reply! Do I understand correctly that the best approach is to have a single project with all the pitch variation tracks stacked, then add a single label track where I set all my ins and outs, and solo each audio track for each export?
