I have audacity 3.7.5 And cannot find vocal remover or, Vocal Reduction and Isolation I also DL’d. Vino ai effects but still cannot find anything to remove vocals. I looked here to find out how but cannot find anything.
OpenVINO has Music Separation.
The old Vocal Reduction plug-in (vocalrediso.ny) is here.
In Audacity 3.7.5, the vocal remover is under Effects → Vocal Reduction and Isolation.
If you don’t see it:
Make sure you’ve updated the “Effect” menu after installing any additional plugins. Close and reopen Audacity if needed.
Check that the plugin is enabled:
Go to Effects → Add / Remove Plugins…
Look for “Vocal Reduction and Isolation” or “VST / Nyquist” plugins you installed.
Click Enable and then OK.
Once enabled, it will show up in the Effects menu.
If it still doesn’t appear, the plugin might not be compatible with your OS or Audacity version. In that case, you can try using the built-in vocal reduction in the latest Audacity 3.x or a dedicated plugin like VST3 “Vocal Remover.”
