am using Audacity 3.0.2 on Windows 10
So, I take my portable cassette player (is a NAXA Electronics NPB-300), insert a tape, press RECORD, turn the volume to zero, count to 10, turn the volume to 10 and count to 10 again. When played back you will hear the speaker noise/audio on the 2nd counting.
- is there a technical term for the speaker noise audio ?
- how can it be removed with Audacity ?
Thank you.
Edwin
Are you actually trying to record to a cassette or are you trying to digitize an old cassette?
Sorry, I don’t understand. With the recording volume at zero I’d expect you to record silence. With the volume turned-up I’d expect you to record yourself counting…
To me, “speaker noise” would be rattle or buzz when the volume is turned-up too loud but that would be the playback volume not the recording volume.
As with DVDdoug, I am not sure what it is you are trying to accomplish. Are you recording to a USB memory stick? Have you read the manual, which reads, in part:
“The automatic level control(ALC)will set the record level for optimum recordings,regardless of volume setting.”
See: https://naxa.com/supportcenter/download/searchmodel/?sku=NPB-300
How does Audacity fit into this picture?
In general, if you have a recording in Audacity with background noise, select a portion of the audio with noise only and get a noise profile via Effects > Noise Reduction. Then select the whole recording and run Noise Reduction again. See: Noise Reduction
