Removing crackling from already edited audio?
Good afternoon,
I recently got an audio file that was edited to add an echo effect, I was enjoying it when I started hearing this horrendously loud cracking in the audio file. I would fix it myself, but I cannot find the original song, nor do I know what effects they may have added, so if anyone knows what I can do to remove these cracks without physically going into the audio file and picking out the sounds, please let me know.
Here’s the file: An example can be found between 1:59-2:02 for anyone not wishing to listen to the entire thing:
https://drive.google.com/file/d/1rNq9_dsdajs_-PP3P6BA-t2FWm4Kx9nl/view
Cheers,
Sargon
OK, so the clicks in this recording seem to be from clipping. I do not have a lot of experience with repairing this kind of damage, but you can try
running Effect > Clip Fix here: https://manual.audacityteam.org/man/clip_fix.html
or De-clicker here: https://forum.audacityteam.org/t/updated-de-clicker-and-new-de-esser-for-speech/34283/1
I hope this helps. :smiley:
The Clip fix worked like a charm, thank you very much!
:smiley:
