I have tried to follow instructions; The instructions say to click on the stereo track drop-down menu. There is no stereo track drop-down menu where indicated. Please help.
If the vocals are exactly in the “center” (identical and in-phase in both channels) they can be removed completely. But usually there are other sounds in the center and you rarely get “professional” results.
What instructions?
There is a way to do it manually but there are plug-ins to do it automatically and some of the plug-ins are more advanced than the manual methods.
You can try Vocal Reduction and Isolation. (If you have an older version of Audacity it may already be built-in.) Or OpenVINO Music Separation.
