Remove pop window
suddenly my audacity started showing a pop up window everytime I do commands, saying “Audacity Information” and then a specific list of information, fx
“operation took 0,000000001 seconds. Poll was called 0 times and took 0,00000001 seconds”
It is very irritating, so how do I remove this
I have no idea what you did to switch this behaviour on, but you could reset the configuration by using the menu command “Tools → Reset configuration”.
thx, but it did not help
What OS and audacity version are you using?
