I am a noob and I am trying to remove drum beats from the following audio file but not having any luck. I tried Vocal Remover + Noise Profile that’s out there on youtube but it’s not helping.
Can someone please remove the background drum beats for me? If you could also tell how you did it, I will greatly appreciate it. Thank you!!
While creating karaoke tracks I occasionally find one instrument is too “in your face”. Usually it’s the snare or kick drum. I have successfully reduced the volume in some files but it is a bit labour/time intensive, especially when there are as many drum beats as in your sample.
Open the track.
Zoom into the forst drumbeat to be reduced (select it & Ctrl E)
Reselect the drumbeat if you want a more precise selection
Adjust it’s volume using Amplify
Fiddle around with the width of the selection and the amplification factor until you are happy with it
Move to the next drumbeat with the arrows on the bottom timebar and select it
Repeat Amplify (Ctrl R)
It’s a slow, tiring process but the only way I know. Good luck.
There is another simpler technique for single instrument management. Cut (a copy of) the song so you have a “pile” of only that instrument—as much as possible. Use the pile as Effect > Noise Reduction > Profile. Then apply Noise Reduction to the whole song. As long as you don’t restart Audacity, the profile and the effect should stick pass after pass.
