I am using Windows 10
I am using Audacity 2.2.2
How to remove the screeching sound when I hit the record button.
Hello: Attempted to deleted a portion of the track. I hit CTL + A, then I hit the record button. Instead of recording I got a loud screeching sound, which would not go away. The monitoring bars on top reads.
From 57 to 12 the light is green,
6 is yellow and 3 is orange.
Question how do I turn off the noise to set it back to record normally?
Attempting to learn the system, it appears as if one of the 6 icons next to the Red record button is on. I don’t know if that is causing the squeaking sound.
Again how do I get the system back to normal recording?
I’m thanking you in advance for a speedy reply.
