Hola,
He grabado un archivo, pero no he guardado el proyecto ¿Hay manera de recuperarlo?
Gracias de antemano.
Hola,
So once you exit Audacity, the project gets deleted.
If you have not yet exited Audacity, then File > Export could to the trick. If you have not yet exited Audacity, but have inadvertently deleted the track, Edit > Undo or Redo can sometimes bring it back.
