Hi, I’m trying to recreate a specific audio effect in Audacity.
It’s a echo, reverb, something that makes your voice have a bit of a booming quality to it. You can hear what I’m aiming for with the first 10 seconds (Specifically, from 0:03 to 0:10) of this YouTube video: https://www.youtube.com/watch?v=d5PLEPD_tOc
I’ve tried all the audio effect, and though using the echo effect on the section of audio I want with the parameters of 0.1 delay time (seconds) and a decay factor of 0.5 gives some kind of step towards it(?), it’s not what I’m looking for by far.
The answer might lie elsewhere outside of the effects tools, but if it does it’s beyond me at the moment.
I’m on Windows 8.1 with Audacity 2.0.5, installed via the .exe.
I would be very appreciative if you could help me out here.
Thanks you for reading this,
Rarefoil
