Hi,
I’m running Audacity 2.1. My Mac is running 10.11.2. Unfortunately I should say because this is sort of the problem, or rather: my now mute recovered files/projects that hadn’t been saved before a new OS was installed, without asking permission, by other user on same Mac…
My directory is in /var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten
Attached is the log file. Any hope of recovering the actual audio?
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d02/e0002f1d.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d02/e00023fb.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d00/e0000c7a.au'
20:04:44: Varning: Saknar data blockfil: '/var/folders/0t/hc4mll0x43jfth8tcs8_cv1w0000gp/T/audacity-Marten/project893826679/e00/d04/e0004754.au'
The structure is an AUP text file with the instructions to Audacity how to construct the show out of the contents of the similarly-named _DATA folder. The _DATA folder contains a deeper directory structure with the AU files.
The AUP file and the _DATA folder must live in the same location or folder for the show to open.
You should be able to look and see both.
Go (top of desktop) > Go To Folder (see attached).
