Recover my files
Hi i forgot to save my files now i cant recover them
please help
Hi,
I downloaded your zip file from Dropbox and extracted it. Once I’d done that I renamed each file to remove the ‘unsaved’ part of the name leaving just .aup3. I could then open and play each project.
I suggest you copy each one and then rename the copy. It tells you it wasn’t saved last time, which you knew, but you MUST save it this time. I wasn’t able to re-open the original a second time so I had to re-extract the zip file. I use version 3.7.7 of Audacity. See if the same process works for you. If it does, great. If not, I will export them as WAV files and send them to you using SwissTransfer.com.
Mark B
Thank you so much
Did you try what I suggested and find it worked OK? If so, I will delete the files on my PC. Please could you confirm before I do that?
Thanks.
yes im sorted, i tried what you suggested and it worked.
Thank you
