Recordings breaking up
Rather strange problem using latest version of audacity.
The lower project rate I use, the worse the break up in recordings.
I am having to use 88200 to get a stable recording, which obviously means large files.
Can anyone help?
I have tried earlier versions of audacity and the same thing applies.
I have quite an old PC (Athlon 64x2 5400+) 4GB Ram and plenty of hard disk space but don’t think that is the issue.
What is confusing me is the lower the project rate, the worse the problem is.
Here is a screen shot at 8000
http://s30.postimg.org/d4b7g7dlc/audacity8000.jpg
What happens at 44100 Hz sample rate?
Which exact version of Audacity are you using? (look in “Help > About Audacity”)
Which version of Windows?
What are you trying to record and what equipment are you using (make + model number where possible).
The poster is on XP.
You could see if any of this helps: http://wiki.audacityteam.org/wiki/Managing_Computer_Resources_and_Drivers.
You can always change the project rate to 44100 Hz when you export.
I get slight random gaps for split seconds, this doesn’t seem to happen at 88200 though.
What (make and model number) is connected to the SoundMax Line In?
Thanks for replies.
I am using version 2.1.2, but it happens on earlier versions also.
At 44100 I still get random gaps for split seconds, at 88200 I haven’t noticed any.
I know I can export with lower project rates, but would like to know how to cure the problem.
It happens with any device I use via line in on my sound card.
The monitored sound is perfect, but I can see the fault occuring during recording on the scrolling wave form.
The sound card is built in to the ASUS M2N32WS_PRO motherboard and has the latest driver (Soundmax integrated digitalHD audio)
XP Pro 32 bit 2002 with service pack 3
Double post
We can’t remotely solve the problem for you. You have old hardware and an obsolete operating system. :wink:
You could look in the SoundMax control panel to see if it has any sample rate settings but I doubt that.
Does using Windows DirectSound host in Device Toolbar make any difference?
Otherwise please try the link previously suggested: http://wiki.audacityteam.org/wiki/Managing_Computer_Resources_and_Drivers.
OK, thanks for trying to help.
Selecting direct sound makes no difference
Another test would be to make LineIn the default Recording Device in Sounds and Audio Devices then record in Windows Sound Recorder (you are limited to 60 seconds of recording).
If Sound Recorder does not break up, perhaps it could indicate interference with Audacity by some security or anti-virus app.
Thanks, but I do not have the option to make LineIn the default Recording Device in Sounds and Audio Devices.
The only option is SoundMAX HD Audio.
Having selected “SoundMax HD Audio” as the sound recording device, click the “Advanced…” button. See: Windows Sounds and Audio Devices.
Advanced is greyed out, but sound recorder recorded from line in anyway.
At 8000 mono record selected with XP sound recorder I get same chronic audio break up.
At 48000 stereo record selected with XP sound recorder, recording in clear :confused:
Well, that’s just broken. :wink:
Did you build this computer yourself?
Unless you are absolutely sure you have the correct audio driver, please attach a DXDiag report. Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
Yes, I built the PC Myself and everything works fine except this :laughing:
All test with dxdiag run fine and I have never had any play back issues with video or audio files.
No errors in device manager either.
System Information
Time of this report: 2/26/2016, 14:49:40
       Machine name: HAL
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
           Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5400+,  MMX,  3DNow (2 CPUs), ~2.8GHz
             Memory: 3326MB RAM
          Page File: 923MB used, 4286MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: DirectSound test results: All tests were successful.
        Sound Tab 2: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce GT 220
     Manufacturer: NVIDIA
        Chip type: GeForce GT 220
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0A20&SUBSYS_000019F1&REV_A2
   Display Memory: 1024.0 MB
     Current Mode: 1360 x 768 (32 bit) (60Hz)
          Monitor: Plug and Play Monitor
  Monitor Max Res:
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0011.9045 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 9/29/2009 18:58:17, 5845632 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 9/29/2009 18:58:17, 7753888 bytes
Device Identifier: {D7B71E3E-4960-11CF-1459-0B2003C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0A20
        SubSys ID: 0x000019F1
      Revision ID: 0x00A2
      Revision ID: 0x00A2
      Video Accel: ModeMPEG2_C ModeMPEG2_D
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: SoundMAX HD Audio
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_104381F6&REV_1002
        Manufacturer ID: 65535
             Product ID: 65535
                   Type: WDM
            Driver Name: ADIHdAud.sys
         Driver Version: 5.10.0001.6110 (English)
            WHQL Logo'd: Yes
          Date and Size: 2/25/2016 18:12:34, 293888 bytes
            Other Files:
        Driver Provider: AnalogDevices
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
 Static/Strm HW 3D Bufs: 33, 32
              HW Memory: 0
       Voice Management: Yes
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
               Registry: OK
      Sound Test Result: All tests were successful.
            Description: NVIDIA High Definition Audio
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_000A&SUBSYS_10DE0101&REV_1001
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: nvhda32.sys
         Driver Version: 1.00.0000.0058 (English)
            WHQL Logo'd: Yes
          Date and Size: 9/29/2009 18:58:31, 56992 bytes
            Other Files:
        Driver Provider: NVIDIA Corporation
              Cap Flags: 0xB5B
    Min/Max Sample Rate: 32000, 48000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xCCC
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  NVIDIA High Definition Audio, Software (Kernel Mode), Output, DLS, Internal
                  Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 8/23/2001 14:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 00:48:02, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 00:09:48, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 4/14/2008 00:09:48, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 142.2 GB
Total Space: 152.6 GB
File System: NTFS
      Model: WDC WD1600AAJS-60WAA0
      Drive: D:
 Free Space: 67.2 GB
File System: NTFS
      Model: ST3160215ACE
      Drive: E:
 Free Space: 22.7 GB
Total Space: 190.8 GB
File System: NTFS
      Model: SAMSUNG SP2014N
      Drive: F:
 Free Space: 16.2 GB
Total Space: 286.2 GB
File System: NTFS
      Model: Maxtor 6L300S0
      Drive: G:
      Model: TSSTcorp CDDVDW SH-S223C
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:48, 62976 bytes
System Devices
     Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DE&DEV_0BE2&SUBSYS_000019F1&REV_A1\4&13D46659&0&0120
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5012 (English), 10/27/2004 15:21:36, 138240 bytes
     Name: NVIDIA GeForce GT 220
Device ID: PCI\VEN_10DE&DEV_0A20&SUBSYS_000019F1&REV_A2\4&13D46659&0&0020
   Driver: g:\winxp32\display\NvCplSetupInt.exe, , 0 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.9045 (English), 9/29/2009 18:58:17, 7753888 bytes
   Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:17, 5845632 bytes
   Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:18, 868352 bytes
   Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:25, 2002944 bytes
   Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:25, 1706528 bytes
   Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:26, 2189856 bytes
   Driver: C:\WINDOWS\system32\nvdata.bin, 9/29/2009 18:58:26, 1597690 bytes
   Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.9045 (English), 9/29/2009 18:58:29, 10457088 bytes
   Driver: C:\WINDOWS\system32\nvcod.dll, 1.05.0010.0055 (English), 9/29/2009 18:58:18, 155648 bytes
   Driver: C:\WINDOWS\system32\nvcodins.dll, 1.05.0010.0055 (English), 9/29/2009 18:58:18, 155648 bytes
     Name: NVIDIA nForce 590/570/550 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&6A
   Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0687 (English), 8/21/2006 17:24:28, 105344 bytes
   Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 8/21/2006 17:24:30, 363008 bytes
   Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 8/21/2006 17:24:30, 363008 bytes
   Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 8/18/2006 09:28:32, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&69
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&68
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_0378&SUBSYS_00000000&REV_A2\3&2411E6FE&0&A8
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:46, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B8
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_00000000&REV_A2\3&2411E6FE&0&90
Device ID: PCI\VEN_10DE&DEV_0375&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B0
Device ID: PCI\VEN_10DE&DEV_0374&SUBSYS_00000000&REV_A2\3&2411E6FE&0&A0
     Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&80
   Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0003.6531 (English), 9/11/2006 18:45:38, 19968 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6531 (English), 9/11/2006 18:45:16, 1161088 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0002.6531 (English), 9/11/2006 18:44:58, 261632 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvtcp.sys, 1.00.0003.6531 (English), 9/11/2006 18:45:26, 110592 bytes
   Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 9/11/2006 18:43:42, 11264 bytes
   Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 9/11/2006 18:43:42, 11264 bytes
   Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 9/11/2006 16:06:48, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_81F61043&REV_A2\3&2411E6FE&0&71
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&70
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_81FB1043&REV_A1\3&2411E6FE&0&60
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:30, 24960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:32, 96512 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 14:00:00, 3328 bytes
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&51
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 05:41:56, 7168 bytes
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_81FB1043&REV_A1\3&2411E6FE&0&50
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 17152 bytes
     Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_CB8410DE&REV_A1\3&2411E6FE&0&40
   Driver: n/a
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_81FB1043&REV_A2\3&2411E6FE&0&49
   Driver: n/a
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:42, 37248 bytes
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&05
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&02
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&01
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&04
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&03
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F4&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&00
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&06
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_81FC1043&REV_A2\3&2411E6FE&0&07
   Driver: n/a
Device ID: PCI\VEN_109E&DEV_0350&SUBSYS_00000000&REV_12\4&1CEFD014&0&3070
   Driver: C:\WINDOWS\system32\DRIVERS\pctvw2k.sys, 4.00.0001.0015 (German), 1/23/2001 11:03:32, 42448 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\PCTVAud.sys, 1.00.0000.0001 (German), 2/8/2000 12:25:50, 2145 bytes
   Driver: C:\WINDOWS\system32\UnInW2k.exe, 4.00.0001.0003 (German), 5/2/2000 15:23:28, 73728 bytes
   Driver: C:\WINDOWS\system32\pctvcap.dll, 4.00.0000.0011 (English), 5/4/2000 16:37:18, 47313 bytes
   Driver: C:\WINDOWS\system32\PCTVuser.dll, 4.00.0000.0001 (English), 1/24/2000 18:25:18, 32768 bytes
   Driver: C:\WINDOWS\system32\Mcipctv.dll, 4.00.0000.0001 (English), 2/8/2000 17:09:20, 29408 bytes
   Driver: C:\WINDOWS\system32\io_pctv.dll, 3.00.0000.0000 (English), 4/7/2000 16:31:54, 36864 bytes
     Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_815B1043&REV_00\4&1CEFD014&0&5870
   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:16:20, 61696 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/14/2008 00:16:20, 53376 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:21:26, 61824 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:21:26, 60800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Device ID: PCI\VEN_1033&DEV_0125&SUBSYS_00000000&REV_06\4&9D9531C&0&0190
Device ID: PCI\VEN_1033&DEV_0125&SUBSYS_00000000&REV_06\4&9D9531C&0&0090
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
   Driver: n/a
DirectX Components
   ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 279552 bytes
 ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 1179648 bytes
 d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 824320 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:18 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:18 17920 bytes
   dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:22 3072 bytes
 dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:20 3072 bytes
 dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:20 83456 bytes
  dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 116736 bytes
  dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 53520 bytes
  dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 158720 bytes
 dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 394240 bytes
     joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:42 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 76800 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:04 35328 bytes
  dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 71680 bytes
  dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 35840 bytes
 dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 105984 bytes
 dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 82432 bytes
   dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 619008 bytes
   dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 1227264 bytes
 dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 14:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 05:41:58 1028096 bytes
 wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:42:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:50 70656 bytes
 devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:52 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 05:41:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:58 35328 bytes
 mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:44 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:00 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 20480 bytes
    qasf.dll: 9.00.0000.4503 English Final Retail 4/14/2008 05:42:04 237568 bytes
    qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 192512 bytes
     qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 279040 bytes
    qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 386048 bytes
   qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 22:51:34 733696 bytes
  quartz.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 1288192 bytes
 strmdll.dll: 4.01.0000.3936 English Final Retail 4/14/2008 05:42:08 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 05:42:44 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 05:42:44 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 05:41:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 05:41:56 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 05:41:56 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 05:41:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 05:41:56 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 05:42:44 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:02 203776 bytes
      ks.sys: 5.03.2600.5512 English Final Retail 2/25/2016 18:12:34 141056 bytes
  ksproxy.ax: 5.03.2600.5512 English Final Retail 2/25/2016 18:12:32 129536 bytes
  ksuser.dll: 5.03.2600.5512 English Final Retail 2/25/2016 18:12:32 4096 bytes
  stream.sys: 5.03.2600.5512 English Final Retail 2/25/2016 18:12:32 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:52 5376 bytes
   mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 00:09:52 4992 bytes
 mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 7552 bytes
  swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:44 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:02 1428992 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 30208 bytes
   msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:02 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:12 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
MPC - Video decoder,0x00400000,1,1,MPCVideoDec.ax,1.03.1249.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ffdshow Video Decoder,0x00400000,2,1,ffdshow.ax,1.02.4447.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
MPC - Matroska Source,0x00600000,0,0,MatroskaSplitter.ax,1.05.0002.3236
ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.02.4447.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.02.4447.0000
ESink,0x00200000,1,0,ESink.ax,1.00.0000.0000
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.02.0000.0027
ffdshow Audio Decoder,0x00400000,1,1,ffdshow.ax,1.02.4447.0000
Pinnacle Video Renderer,0x00200000,1,0,pcle_ovr.ax,4.00.0000.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.05.0002.3236
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,4.02.0000.0027
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0001
MPC - Matroska Splitter,0x00600000,1,1,MatroskaSplitter.ax,1.05.0002.3236
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.67.0000.0115
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
MediaSampleGrab,0x00200000,1,1,FrameGrab.ax,1.00.0000.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0002
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
MSAudioRender,0x00200000,1,0,MSAudioRender.ax,4.01.0000.0000
PCLE_MPEGEDIT2,0x00200000,0,0,MPEGEdit2.ax,1.00.0000.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,4.02.0000.0027
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
ESinkAudio,0x00200000,1,0,ESinkAudio.ax,1.00.0000.0000
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3 Decoder,0x00600001,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.05.0002.3236
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.02.0000.0027
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.05.0002.3236
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.02.0000.0027
PCLE_VIDEO7,0x00200000,0,0,PCLEVideo7.ax,7.00.0002.0000
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
AXVBIRender,0x00200000,1,0,axvbirender.ax,4.03.0000.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.02.0000.0027
PCLE_MPEGEDIT,0x00200000,0,0,MPEGEdit.ax,1.00.0000.0000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.11.0288.0000
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.11.0288.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.02.0000.0027
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.02.0000.0027
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0001
MPC - MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.05.0002.3236
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,4.02.0000.0027
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0002
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.02.0000.0027
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.02.0000.0027
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.02.0000.0027
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.02.0000.0027
MSRepair,0x00200000,1,1,MSRepair.ax,1.00.0000.0000
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.11.0288.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
VSFilter,0x00200000,2,1,vsfilter.dll,1.07.0010.0101
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0002
VSFilter (auto-loading version),0x00800002,2,1,vsfilter.dll,1.07.0010.0101
PCLE_CONVERISON,0x00200000,0,0,ColorConvert.ax,1.00.0000.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
PIM1Compress,0x00200000,1,1,pim1compress.AX,4.00.0000.0001
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.11.0288.0000
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.02.0000.0027
AC3Filter,0x00400000,1,1,ac3filter.ax,1.03.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.02.0000.0027
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.02.4447.0000
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.67.0000.0115
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.02.0000.0027
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.05.0002.3236
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
AXWavRender,0x00200000,1,0,axwavrender.ax,4.01.0000.0000
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.02.0000.0027
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
MPC - MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.05.0002.3236
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.02.0000.0027
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.02.0000.0027
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.02.4447.0000
MPC - Mpeg Splitter (Gabest),0x00400000,1,1,MpegSplitter.ax,1.05.0002.3236
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
AVI_PASS,0x00800000,1,1,AVI_PASS.ax,2.00.0000.0000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.02.0000.0027
RealMedia Splitter,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0002
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
MPC - MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.05.0002.3236
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
XLCompress,0x00200000,1,1,XLCompress.ax,1.00.0000.0000
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.67.0000.0115
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.02.0000.0027
LAV Video Decoder,0xff800000,1,1,LAVVideo.ax,0.67.0000.0115
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Haali Video Sink,0x00200000,1,0,splitter.ax,1.11.0288.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.02.0000.0027
XLDecompress,0x00600000,1,1,XLDecompress.ax,1.00.0000.0000
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
AudioGrab,0x00200000,1,1,AudioGrab.ax,1.00.0000.0000
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.02.4447.0000
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.02.0000.0027
XLCompress,0x00200000,0,0,XLCompress.ax,1.00.0000.0000
XLDecompress,0x00200000,0,0,XLDecompress.ax,1.00.0000.0000
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
PCLEPIM1 32-bit Compressor,0x00200000,1,1,qcap.dll,6.05.2600.5512
PCLEPIXL 32-bit Compressor,0x00200000,1,1,qcap.dll,6.05.2600.5512
miroVIDEO-XL 32-bit Compressor,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Audio Capture Sources:
SoundMAX HD Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SoundMAX HD Audio,0x00000000,0,0,,
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,,5.03.2600.5512
Video Capture Sources:
pctvcap.dll,0x00200000,0,0,qcap.dll,6.05.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5512
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: NVIDIA High Definition Audio,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming System Devices:
NVIDIA High Definition Audio,0x00200000,3,1,,5.03.2600.5512
SoundMAX HD Audio,0x00200000,19,3,,5.03.2600.5512
Playback is much less demanding than recording.
If you post the DXDiag report it is possible to check that you have the correct audio drivers. Of course you can check that yourself if you know how to do it.
If you already have the correct drivers then I have nothing to add, beyond going through every point on the Wiki page I pointed you to.
If you prefer to post long text input inline, please use the Code button. Done.
Thanks Gale.
Yes I understand that, but surely I would encounter problems recording at 48000 rather than 8000?
It depends what the problem is. Recording at 88200 Hz then exporting at 44100 Hz is not a terrible solution.
Do you have a security app that monitors apps and processes for what they do?
Have you always had this problem or only just now?
Please confirm whether you know how to locate the required audio drivers from the DXDiag report. I assume you do, if so I won’t be replying further, unless you have new questions.
