Recording without Overdubbing
I wish to record on track 2 clean (without overdubbing from track 1). I have two soundcard:s U24 for recording and DDJ FLX 6 (pioneer) for playback. I use the Italian version of Audacity. Can you help me?
P.S.: I read that in the english version I could do something in the transport menu but this menu is not present in the Italian version
Normally you can only record from one device at a time and you shouldn’t “accidently” get overdubbing/mixing unless you select something that’s called “loopback” as your recording device.
“Loopback” records what’s coming OUT of your soundcard instead of recoding from an analog input. Normally, loopback is used to record streaming audio where there is no input connection.
If you want to record from two devices at the same time then you’ll have to use loopback to record EVERYTHING that’s coming out of one soundcard/device.
