Hey
when I’m recording randomly it will cut out for like 1/8th of a second and nothing will be recorded then it goes back to recording normally
how do I fix this problem?
thanks
-James
Hey
thanks
-James
While recording with my steinberg CI1 on windows 7 64bit the music will skip but it makes a noise before it does and then it dosent pick up any sound for a fraction of a second is their a way to fix this? i tried lowering the audio quality to 16 bit but it dosent help I uploaded a pic of what happens
I have already went through that list and and been able to complete most of this list but it hasn’t helped at all is their anything else that I can do?
How often do these gaps occur?
Can you see any pattern to when they occur?
their is no pattern sometimes it happens twice within a few seconds and other times it wont happen over a minute
Do you have Sound Activated Recording clicked on?
Edit > Preferences > Recording > Sound Activated Recording. If you have a quiet space in your recording, that’s likely to stop recording and then pick up again.
This doesn’t have a wall power supply, does it? It gets all of it’s operating voltages from the USB cable? Are you going through a USB Hub with other stuff? USB Audio hates that and it will put holes in your music. Try a different USB connection on your computer, or just pull and plug the existing one a couple of times.
Carefully check through what applications and processes are running on your computer. Close all non-essential applications and stop all non-essential processes, then make a test recording.
Sound activated recording is not on, yes their is no power hub the CI 1 gets all its power through the usb cable that is plugged directly into the back of my computer i have tried switching usb ports but it dosent seem to make a difference
I’m not really sure what applications and processes are essential but I turned off most of them it did not make a difference
What specification is your computer?
Have you tried error checking and defragmenting your hard drive?
A bit of a long shot, but do you use Norton 360?
my computer is a pentium 4 3ghz 2.99ghz, 2gb ram, 64bit,
and yes I am using Norton
A particularly aggressive virus protection program can insist on inspecting every file transfer including the real time file management that recording and playback does – thereby making them no longer real time.
is their a way to make Norton stop inspecting every file?
I don’t use Norton, but there should be some way to add “exceptions” to what and when it scans.
To “prove the problem” it may be worth temporarily disconnecting from the Internet and shutting down Norton, then make a test recording.
OK I added audacity to be excluded list from Norton and it still has the same problem
ok so i have turned off Norton and the internet and it still has the same problem i went back to the store and exchanged the steinberg unit for a new one and it has the same problem replaced the mic and cord so is my computer even good enough to run this program? here is the system specs, sorry I’m not very good with computers so I’m not sure if this is to much info
System Information
Time of this report: 6/26/2012, 21:17:49
Machine name: WAYNE-HOME-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 11/18/05 09:25:04 Ver: 08.00.10
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs), ~3.0GHz
Memory: 2048MB RAM
Available OS Memory: 2048MB RAM
Page File: 1649MB used, 2444MB available
Windows Dir: C:Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4300/4500 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x954F)
DAC type: Internal DAC(400MHz)
Device Key: EnumPCIVEN_1002&DEV_954F&SUBSYS_02A81043&REV_00
Display Memory: 1274 MB
Dedicated Memory: 506 MB
Shared Memory: 767 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: VX2239 SERIES
Monitor Id: VSC5225
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1077 (English)
Driver Version: 8.850.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/20/2011 02:07:48, 795648 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-D60F-11CF-C677-A222BEC2C535}
Vendor ID: 0x1002
Device ID: 0x954F
SubSys ID: 0x02A81043
Revision ID: 0x0000
Driver Strong Name: oem22.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R7X:8.850.0.0:pciven_1002&dev_954f
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIOFUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_0905
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: n/a
Date and Size: 11/20/2010 03:44:23, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Line (Steinberg CI1)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: USBVID_0499&PID_1501&REV_0100
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ysusb64.sys
Driver Version: 1.06.0002.0008 (English)
WHQL Logo'd: n/a
Date and Size: 3/6/2012 15:47:26, 109896 bytes
Other Files:
Driver Provider: Yamaha Corporation.
Cap Flags: 0x0
HW Memory: 0
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Headphones (High Definition Audio Device)
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Description: Line In (High Definition Audio Device)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone (High Definition Audio Device)
Cap Flags: 0x0
Format Flags: 0x0
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Comfort Curve Keyboard 2000
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x00DD
FF Driver: n/a
Device Name: Microsoft® Comfort Mouse 4500
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x076C
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2658
| Matching Device ID: usbroot_hub
| Service: usbhub
+-+ Yamaha Steinberg USB Audio
| | Vendor/Product ID: 0x0499, 0x1501
| | Matching Device ID: usbvid_0499&pid_1501
| | Service: ysusb64
Gameport Devices
PS/2 Devices
+ Microsoft USB Comfort Curve Keyboard 2000 (IntelliType Pro)
| Matching Device ID: hidvid_045e&pid_00dd&mi_00
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: rootrdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Microsoft Comfort Mouse 4500 (IntelliPoint)
| Matching Device ID: hidvid_045e&pid_076c&col02
| Upper Filters: Point64
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: rootrdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 203.5 GB
Total Space: 305.1 GB
File System: NTFS
Model: ST3320418AS ATA Device
Drive: D:
Model: HL-DT-ST DVDRAM GSA-H10N ATA Device
Driver: c:windowssystem32driverscdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2666
Device ID: PCIVEN_8086&DEV_2666&SUBSYS_00000000&REV_033&11583659&0&E3
Driver: n/a
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Device ID: PCIVEN_8086&DEV_2658&SUBSYS_80A61043&REV_033&11583659&0&E8
Driver: n/a
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2664
Device ID: PCIVEN_8086&DEV_2664&SUBSYS_00000000&REV_033&11583659&0&E2
Driver: n/a
Name: Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Device ID: PCIVEN_8086&DEV_2651&SUBSYS_26011043&REV_033&11583659&0&FA
Driver: n/a
Name: ITE IT8211 ATA ATAPI Controller
Device ID: PCIVEN_1283&DEV_8211&SUBSYS_81381043&REV_114&23C0B1C&0&18F0
Driver: n/a
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2662
Device ID: PCIVEN_8086&DEV_2662&SUBSYS_00000000&REV_033&11583659&0&E1
Driver: n/a
Name: Intel(R) 82801FB LPC Interface Controller - 2640
Device ID: PCIVEN_8086&DEV_2640&SUBSYS_00000000&REV_033&11583659&0&F8
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCIVEN_1002&DEV_AA38&SUBSYS_AA381043&REV_004&30131F0D&0&0108
Driver: n/a
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2660
Device ID: PCIVEN_8086&DEV_2660&SUBSYS_00000000&REV_033&11583659&0&E0
Driver: n/a
Name: ATI Radeon HD 4300/4500 Series
Device ID: PCIVEN_1002&DEV_954F&SUBSYS_02A81043&REV_004&30131F0D&0&0008
Driver: n/a
Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Device ID: PCIVEN_8086&DEV_265C&SUBSYS_80A61043&REV_033&11583659&0&EF
Driver: n/a
Name: Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Device ID: PCIVEN_8086&DEV_2581&SUBSYS_00008086&REV_0E3&11583659&0&08
Driver: n/a
Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Device ID: PCIVEN_8086&DEV_266F&SUBSYS_80A61043&REV_033&11583659&0&F9
Driver: n/a
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Device ID: PCIVEN_8086&DEV_265B&SUBSYS_80A61043&REV_033&11583659&0&EB
Driver: n/a
Name: Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580
Device ID: PCIVEN_8086&DEV_2580&SUBSYS_25808086&REV_0E3&11583659&0&00
Driver: n/a
Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
Device ID: PCIVEN_8086&DEV_266A&SUBSYS_80A61043&REV_033&11583659&0&FB
Driver: n/a
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Device ID: PCIVEN_8086&DEV_265A&SUBSYS_80A61043&REV_033&11583659&0&EA
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCIVEN_8086&DEV_244E&SUBSYS_00000000&REV_D33&11583659&0&F0
Driver: n/a
Device ID: PCIVEN_8086&DEV_2668&SUBSYS_814E1043&REV_033&11583659&0&D8
Driver: n/a
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Device ID: PCIVEN_8086&DEV_2659&SUBSYS_80A61043&REV_033&11583659&0&E9
Driver: n/a
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCIVEN_8086&DEV_1064&SUBSYS_80F81043&REV_034&23C0B1C&0&40F0
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.01.0004.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,8.05.0000.27572
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
MainConcept AAC Decoder,0x00800000,1,1,mc_dec_aac_ds.ax,8.05.0000.24552
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
BPM Metadata,0x001fffff,1,1,MetaBPMu.ax,2.00.0002.0000
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0009.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0012.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Creative AC3 Source Filter,0x00400000,0,1,AC3Srcu.ax,3.02.0001.0000
Creative PCM Raw Writer,0x00200000,1,0,RawWritu.ax,1.00.0000.0000
MainConcept MPEG Push Demultiplexer,0x00200000,1,2,mc_demuxpush_mp2_ds.ax,8.05.0000.24552
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
MainConcept (Adobe2) MPEG Demultiplexer,0x00800100,1,2,,
SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0009.0000
SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0009.0000
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
MainConcept (Adobe2) AVC/H.264 Video Encoder,0x00200000,1,1,,
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0008.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
MainConcept (Adobe2) MPEG Push Demultiplexer,0x00200000,1,2,,
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
Creative Flac Source Filter,0x00400000,0,1,FlacSrcu.ax,1.00.0002.0000
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
Creative MLP Source Filter,0x00400000,0,1,MlpSrcu.ax,3.01.0000.0000
Creative File Reader Filter,0x00400000,0,1,FilReadu.ax,1.00.0005.0000
MainConcept DV-Demultiplexer,0x00800001,1,2,mc_demux_dv_ds.ax,8.05.0000.24552
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
SVM Metadata,0x001fffff,1,1,MetaSVMu.ax,2.00.0002.0000
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
MainConcept AVC/H.264 Video Decoder,0x00800001,1,2,mc_dec_avc_ds.ax,8.05.0000.24552
Track2Filter,0x00200000,0,0,Track2Filter.dll,9.00.0000.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
MainConcept DV Dif Parser,0x00800001,1,1,mc_parser_dv_ds.ax,8.05.0000.24552
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MainConcept (Adobe2) AAC Encoder,0x00100000,1,1,,
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
MainConcept (Broadcast) AVC/H.264 Video Decoder,0x00800002,1,2,mc_bc_dec_avc_ds.ax,8.05.0000.24552
Creative Ogg Source Filter,0x00400000,0,1,OggSrcu.ax,1.00.0001.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
Creative NVF Filter,0x00400000,0,1,NvfSrcu.ax,3.01.0001.0000
MainConcept (Adobe2) Stream Parser,0x00400000,1,2,,
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0007.0000
MainConcept VC-1 Decoder,0x00600000,2,1,mc_dec_vc1_ds.ax,8.05.0000.24552
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,5.00.0001.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0001.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Dump,0x00000000,0,0,,
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
MainConcept DVCPro HD Video Decoder,0x00600000,1,1,mc_dec_dv100_ds.ax,8.05.0000.24552
MainConcept DVCPro 50 Video Decoder,0x00600000,1,1,mc_dec_dv50_ds.ax,8.05.0000.24552
MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,8.05.0000.27572
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Track1Filter,0x00200000,0,0,Track1Filter.dll,9.00.0000.0000
MainConcept DV Video Decoder,0x00600000,1,1,mc_dec_dv_ds.ax,8.05.0000.24552
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0003.0000
Creative LiveRecording Filter SxS,0x00400000,0,1,LiveRecu.ax,5.00.0001.0000
Creative Internet Source Filter,0x00400000,0,1,InetSrcu.ax,1.00.0000.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
MainConcept (Adobe2) DV Video Decoder,0x00600000,1,1,,
MainConcept (Adobe2) DV Video Encoder,0x00200000,1,1,,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MainConcept (Adobe2) AAC Decoder,0x00800000,1,1,,
MainConcept (Adobe2) AVC/H.264 Video Decoder,0x00800001,1,2,,
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Line (Steinberg CI1),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (High Definition Audio ,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
HD Audio Line in,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Microphone 2,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Microphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Steinberg CI1,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio Headphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
Digital Audio (S/PDIF) (High De,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Headphones (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Line (Steinberg CI1),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
Headphones (High Definition Aud,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
