I’ve had some very odd results when recording. Occasionally, after recording, the cursor is ahead of the recording. When I play the recording back, it is faster and higher than intended. I’ve also had the opposite occur. The recording is ahead of the cursor, and the playback is slower than intended.
I’ve check the playback speed, and it is set to 1.0, so it is not likely that.
Any idea what may be causing this?
