I have a roland octa-capture usb device. I want to capture the audio from its 8 inputs.
I checked lsusb, and got
Bus 002 Device 019: ID 0582:0120 Roland Corp.
Next, I went into alsamixer, and switched the device to OCTA-CAPTURE, and it says “This sound device does not have any audio controls”, which is not a good sign.
Next, I opened up audacity, and I can see OCTA-CAPTURE as one of the possible recording options. The options I have are
OCTA-CAPTURE: USB Audio (hw:2,0): Front Mic 0
OCTA-CAPTURE: USB Audio (hw:2,0): Rear Mic 0
OCTA-CAPTURE: USB Audio (hw:2,0): Line 0
OCTA-CAPTURE: USB Audio (hw:2,0): Front Mic 1
OCTA-CAPTURE: USB Audio (hw:2,0): Rear Mic 1
OCTA-CAPTURE: USB Audio (hw:2,0): Line 1
I see 6 things while there should be 8. Also I don’t know what the mapping from the ports on the hardware to the labels in Audacity are.
Anyway, I chose one of the options and then proceeded to connect a mic to all 8 input ports, but all i get in white noise.
Any help at all would be appreciated.
