Recording levels changed only with laptop volume and not with the app Win 11
I have spent a stupid amount of time trying to fix my problem. My knowledge of PC’s is better than many. I can only change recording volume with the laptop volume keys and NOT with the recording level in the app. To the right person this should be a signal as to what’s wrong in my settings. Or is it just a Win 11 issue?
That’s normal if you are using “loopback” or “stereo mix” to record what’s coming out of your soundcard, rather than what’s coming-in through a microphone or other analog input.
The recording volume control also doesn’t usually work with USB mics or other USB input/recording devices.
