Greetings! I am a complete beginner. I want to digitize my old cassette tapes. How do I record from ezcap 232 with micro Sd card [not flashdrive] to my pc. I am using Audacity 2.3.3 and Windows 10. Thank you
Note that ezcap players are typically very cheap (currently available for US $21.32 on aliexpress). As the price is so low it should not be surprising that the build quality is cheap. We have received multiple reports that they don’t last very long - keep your receipt.
I assume that you have the instructions to record with the ezcap 232.
Once the recording is complete:
- If you have a laptop with a compatible card reader, take the card from the ezcap and plug it into the card reader.
- If your computer does not have a card reader, then you will need to buy a card reader. Card readers plug into a normal USB socket. They are available for under $10. Take the card from the ezcap and plug it into the card reader, then plug the card reader into a USB socket in your PC.
Your computer should identify the card as an external drive. You can then use File Explorer to drag MP3 files from the card onto your computer’s hard drive.
