Recording from Crosley turntable
I am trying to record from a Crosley turnbtable, USB connected. It doesn’t appear to be detectiong the input device. At least in doesn’t appear on the recording device list.
It may be hidden, if so can be made to appear on the list, see … https://forum.audacityteam.org/t/recording-device-problem/17269/5
What’s your operating system? Windows? MacOS-X? Linux? (which version?)
USB devices need to be connected to the computer before opening audacity. If you connect it while audacity is running you need to quit audacity and start it again.
Problem is resolved! Thank you!
