So basically I’ve been using audacity to start recording music, I have zero experience in music programming but I thought I might record my guitar and make some songs. I tried recording my guitar using a microphone and the audio was incredibly quiet. I then discovered I could plug my amp into my computer with a USB and I thought that would maybe resolve the issue while giving me a cleaner sound however, it does the same thing. Every input I put into my computer makes the audacity audio extremely quiet, I bass boost it as much as possible and it’s still barely audible despite it’s directly inputted into my amp. Was hoping someone someone has had a similar issue and could possibly help me out. The funny thing is, If I use my regular microphone fitted with my laptop the sound is just fine.
My OS is Windows 10 Home and my laptop is a Lenovo ideapad 110-151br. Not sure if any additional information is needed but I am a complete beginner.
Microphone sensitivity varies and the signal depends on the loudness of the sound and how close the mic is, but a mic right in front of a cranked-up 100W guitar amp usually gives you plenty of signal.
Your computer has a combo mic+headphone jack and it requires a [u]4-conductor TRRS plug[/u]. Does your microphone have that kind of plug? Or, are you using a USB microphone?
If you run Audacity’s Amplify effect, what default amplification do you see? After amplifying, how does it sound?
It’s normal to have some “headroom” with USB audio connections, especially if the there is no volume/gain control for the USB. That’s so a hot pick-up and/or hard strumming doesn’t clip (distort) the analog-to-digital converter. It’s also normal for clean-undistorted and uncompressed guitar to sound a lot quieter than a commercial production (which will be compressed and possibly played through a distorted amp).
