New to recording world. Using Audacity to record drum covers with electronic drums and original audio recordings through a mixer. Within Audacity is there a way to adjust (lower) the electronic drum volume. Basically can you separate and edit drum track and original song audio track.
If your mixer is USB and it can work as a playback device as well as a recording device it will probably work.
Or if you have open (“hear through”) headphones you can listen to the backing-track from your computer speakers with your headphones plugged into the drums or mixer.
