Recording doesn't work on Audacity
I’m using Audacity 375 on my new Windows 11 compuer and I can’t make it record.
Everytime I push the recording button I get an error message. Unfortunately I can’t make a screen dump since my current photo program doesn’t work on Windows 11 either.
But the error message for Audacity looks like this:
“timestamp”: 1761464493,
“event_id”: “155bec857b5b24469901aff1be87ff19”,
“platform”: “native”,
“release”: “audacity@3.7.5”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“version”: “10.0.26100”
“exception”: {
“values”: [
“type”: “Error”,
“value”: “Error opening recording device.\nError code: 0 Success.”,
“mechanism”: {
“type”: “runtime_error”,
“handled”: false
So what is wrong?
I can open and play a previously recorded song but I can’t record anything.
How can i fix this, I really need this program to work now!
What are you trying to record from? Your laptop’s mic? A USB turntable or USB cassette deck? Streaming audio?
Make sure you’ve selected the correct Recording Device.
I was trying to record from Youtube.
Recording Desktop Audio.
Select WASAPI and the loopback device where the sound is coming out (usually your regular soundcard).
And start playback before you start recording. WASAPI can record a silent audio stream but it can’t record “nothing”.
Windows 11 (as did Windows 10) contains the “Snipping Tool” program which lets you take “photos” of your screen (or a part thereof).
I’ve found out that it might be the computer which is the problem, not Audacity.
When I checked the system, I realized that the sound goes “out” but it won’t go “in”.
Not even Microsofts little recorder is usable.
The advice I get from the system is “add an input device”.
But from what?
And what shoul I add.
I’m not a professional sound engineer an I don’t want to meddle with thins I don’t know about and ruin the whole system, especiall not when I have been suffering from a terrible flu for three days with high fever wich makes me so tired and confused that I can hardly think.
And it’s annoying that this ASUS Expertcenter or what the name is has ben equipped with such a lousy sound system with no advice at all how to fix this.
As soon as I’m free of this flu, I’m gonna take a visit to the shop where I bought it and demand the money back if I haven’t fixed the problen before that.
However, I’m grateful for all help I can get when it comes to this problem.
Now, Windows 11 weird system for taking screen dumps has also changed and no information about it.
That made me think that a photo editing program I installed also didn’t work in Windows 11.
When i tried to take a screendump the usual way with the “print screen” button, nothing happened. I thought that the photo program was faulty or not compatible with Windows 11.
I was about to remove it and lay another problem on y heap of problems when I saw you post here. So I started to investigate and found that Windows 11 has a different way with this with screen dumps so now i have to push alt+print screen.
And I wonder why? It has worked fine for so many years, why change it.
Problem solved!
Just before midnight, it came to me like a vision.
I decided to activate the “Stereo Mix” option.
After doing so, all of a sudden Windows sound recorder was working.
But not Audacity!
However, I discovered that it was possible to choose the WASAPI option which hadn’t been possible before and then Audacity worked as it should.
And I’m happy for that!
I guess that the severe flu which I’m suffering from since a couple of days made it difficult for me to think, otherwise it wouldn’t have take n three days to sort this out
Thanks to you who helped me solve thos problem. Your contributions were important! :melting_face:
