Recording does not work - MAC Catalina 10.15.3
Dear all
I’m new to the software and installed it just now. I have set the value for the input resource to the build in microphone of my mac. However, the recording does not work. I tested the same with Garageband to ensure there is no issue with the built in mike an it works there.
I also tried with a BOSE headset - it works for Garageband but not for Audacity.
Is there anyone who experienced the same issue?
This is a known issue in Catalina. The next release version of Audacity will solve the problem, but until then you will need to use this workaround: https://forum.audacityteam.org/t/audacity-2-3-3-under-macos-10-15-catalina/54279/1
