I’m trying to follow the following tutorial, but I need some help doing so.
My first problem: Step 3 is not clear to me:
- Ensure that PulseAudio is running.
How can I do this? What exactly does it mean?
Which version of Linux do you use, ie which distro’?
I use MX Linux 23 xfce.
I use Mint 22.3 so I’ll tell you how I do it and maybe you can adapt it for your setup. I had to install a package called ‘pavucontrol’ (Pulse Audio Volume Control) via my package manager. With that done, I right-click on the volume icon in the task bar. Then I click ‘Sound Preferences’ and then click the ‘Input’ tab. The default is ‘Built-in Audio Analogue Stereo’ and I change it to ‘Monitor of Built-in Audio Analogue Stereo’ when I want to record audio that’s playing on the PC.
Change it back when you’re done recording.
I hope that helps.
Thank you. I tried similar steps, but they don’t work: There is nothing with “monitor” in the name to select from as input.
Therefore, I am trying to strictly follow the tutorial.
I asked ChatGPT and the result is in this link I’m sharing with you: Audio on MX Linux
Thanks. Now it works, after some guesswork.
Here’s a quotation from your ChatGPT link:
Set:
- Audio Host: ALSA
- Recording Device:
pulse(ordefaultifpulseisn’t listed)Click Record in Audacity.
Open PulseAudio Volume Control (
pavucontrol).Go to the Recording tab.
Find Audacity and change Capture from to:
Monitor of Built-in Audio Analog Stereoor whatever your output device is called (“Monitor of Speakers”, “Monitor of HDMI”, etc.).
Well, I couldn’t select “pulse” or “default” as “recording device”, because they aren’t there. I selected “default: Headset Mic:0” instead.
Then, I proceeded exactly as described in the quote, and it worked.
Brilliant!
I can see now that the tutorial might have led to sucess, too. But it is difficult to understand:
