Hello fellow Audacity on iMac users, got a brand iMac with OSX Mavericks. I’m trying to set it up to record sound from a Peavey XR1212. I’m a PC guy, so I’m used to using Audacity to do the same procedure, so I downloaded it and tried to get it to work. The soundboard has an “mp3 in” line as well as an RCA out jack. The iMac does not have a mic in line, only a headphone port. I called Apple Support and the representative informed me that the headphone port on the Mac is smart enough to determine whether I would be using it for headphones of a mic in line, so I should put the mic in line there. So my set up was running an RCA jack (red and white connected to soundboard) with a headphone jack on the other end into the headphone port on the Mac. When I began recording on the through Audacity, the program did not show me the soundboard or the RCA jack as one of the available options to choose to record sound from, it defaulted to the internal mic on the Mac as the only option.
I did not try going from the “mp3 in” line from the soundboard (which btw is a headphone port as well) to the headphone port on the back of the Mac. I use an auxiliary cord to play music from the Mac through the soundboard with these headphone ports, but it just didn’t seem obvious to me that this set up could be used for recording.
While I was downloading Audacity, the Mac was updating garageband, which I have little to no familiarity with. I have done some research and found out that I could potentially use this to record from my soundboard as well. So finally here is my questions:
- The back of the iMac has 4 USB ports, 1 FireWire port, 1 headphone port and 1 ethernet port. Since there is no “mic-in” port, what port can I use to record audio from the soundboard in audacity or garageband?
- If I go from the soundboard with an RCA into the headphone port on the Mac, can I use garageband to record?
iMac, Mac OS X (10.0.x)
