Does the program have the ability to increase the speed of playing a file and save it in this way? for example, my file lasts 1 hour, i.e. 60 minutes. but I want to overwrite it at the output so that it would play for example in 45 minutes. without shortening the file length itself. i.e. only playback speed
thanks for the answer
The Change Speed effect will speed-up (or slow down) playback with pitch increasing (or decreasing) just like speeding-up an analog record or tape.
The Change Tempo effect will speed-up (or slow down) playback without changing the pitch. But, you can get other artifacts (side effects).
How do you define “length”?
“length”? I mean the playing time of the file. It was originally 60 minutes for example. and after the effect of changing the tempo, the playing time will be 45 minutes, for example. (as I wish)
You said, “…without shortening the file length itself.” ![]()
