Ladies and Gentlemen.
I’m nd assistant at Universidad Técnica Federico Sant María,Chile, and I’ve ben uing audacity for years, as part of an english exam, which consists of an “interview”.
Using a headset with integrated microphone, a pps file with the recorded questions and blank spaces runs as the student answers, while audacity is supposed to record both tracks, creating the interview. Unfortunately, for almost a year, audacity has failed to do this, and the questions have been barely recorded only because the headset’s microphone picks up the questions coming from the headphone.
Unfortunately, marking the box to “listen this device” in the microphone are not acceptable option; the questions o the interview can get a little technical, and the PCs are not to of the shelf exactly, so there is a slight lag between what goes into the microphone and what comes out of the headphone, so listening to oneself can get very confusing. Also, the stereo mix only allows me to switch from on sourceto the other; I an either record the sound from the microphone, or from the PC, not both.
Also, because it is a pps file, and often there are lags between one slide and another, merging the tracks after the test is not aceptal either.
in other words, what can I do to SIMULTANEOUSLY record the questions coming from the PC and the answers from the headset (with integrated microphone) without "listening to the microphone.
The attached files sgow that after 2,5 seconds, nothing gets recorded.
best regards,
Javiersansano.
