Recording a separate, synced track
I’m trying to add music to a poem narration. I would like the music, recorded after the narration, to be in a separate, synchronized track so that I can manipulate it separately.
What’s happening is that if I don’t mute the narration track, the next track has both music and narration together.
How do I lay in a second, separate track while hearing the first track so that I can play in response to it?
Using Windows, feeding through a Tascam mixer.
Thanks!
Here is a tutorial on overdubbing (which is what you’re doing): Tutorial - Recording Multi-track Overdubs - Audacity Manual
Wow, thanks so much. This is exactly what I was looking for. I will dig into it.
