USB Phono Plus:
(1) I can record from vinyl records perfectly.
(2). When I connect either the Optical or Coax connectors from my DAT recorder, select LINE, there is no output, even at the headphone jack on the USB Phono Plus.
(3). If I bypass the USB Phone plus and connect the exact same cables using a cheap SPDIF to USB A receiver, I can successfully record. So, this excludes the cables as a source of the problem.
Any idea why this wouldn’t work with the USB Phono Plus? I am using the devices USB powered, recording to a MAC mini via USB A.
