Recorded sound muffled
Hi! I have been using Audacity for 1 year with a Audio-Technica AT2020USB+ Mic.
My voice was alway crystal clear until 2 days ago when I did not change anything in my set up but the recorded result sound smuffled and honestly very different from before.
I attached a before/after and you can hear the recorded sound being very different.
Again, I did not change anything in my set up/configuration at all… Is it an Audacity issue (or an equipment issue, the cable maybe?)
Thanks for the help, really need it :frowning:
Windows update can re-enable “audio enhancements”.
https://support.microsoft.com/en-gb/topic/disable-audio-enhancements-0ec686c4-8d79-4588-b7e7-9287dd296f72
You are my savior, I think it worked :slight_smile: thank you!
