I am able to record audio when I play this from my studio speakers via USB to my laptop however I would like to be able to record some mixes only when I listen to it using my headphones via PFL as I don’t want to disturb my flatmates when they are at home. Is this possible and how would I be able to set this up?
Setup:
Behringer USB mixer
Two Audio Technics turntables
So are you recording now with Windows WASAPI (loopback)? Using that method you “might” be able to still record even if you turn the speaker sound down to zero. Or put a plug in the speaker jack with nothing connected to it.
But you can set the Audacity recording device to the mixer (USB). Use Transport > Software Playthrough to send a delayed copy to the speakers (when you want that), with the speakers set as Audacity playback device. Otherwise turn Software Playthrough off.
What is the exact model number of the mixer? Is it a USB mixer, or analogue and you are also using a UCA 202 (USB)?
