I’m asking for a friend who can only use computer by using a screen reader (NVDA). He would like to record some radio transmissions so it would be easier to listen to afterwards without searching it later online. The problem is that by using the NVDA, audacity also records the voice of screen reader in the beginning (and end) of the recording.
We tried recording by choosing audio host: “Windows WASAPI.” and Recording device: computer’s default speakers or headphones.
Is there any way to not record the voice of the screen reader while capturing audio? Thank you so much in advance!
Yea sry for bad description. i meant internet radio thru a web browser. So we would like to record the same computer audio that is coming through computer speakers.
Audacity can record audio that is coming out through the sound card, but it will record all sound that is coming out through the sound card.
If the computer has two sound cards / audio devices, then it is probably possible to configure NVDA to use one sound card, and Audacity to use the other (no I don’t know how to do that on Windows as I’m primarily a Linux user).
Otherwise, it will be necessary to mute NVDA while the recording is in progress.
