if i do hear a click, which direction should i so with the number? the default buffer lenth is at 100.
the text in the link you provided says to take it down to 0 then come up in incriments of 10. does that mean if i leave it at its default 100 and hear a click, i should input 110 then?
One click at the start of a recording could be normal. The issue described in the link is when there are may clicks, and users describe the recording as “clicky”.
The advice is set it to zero, do a test recording. If clicks, move up to 10. Rinse and repeat.
