Am looking for audio spectrum analysis software recommendations (either audacity plugin or standalone).
Found Raven Lite and Pro http://www.birds.cornell.edu/brp/raven/RavenFeatures.html and checked forum but found nothing relevant.
Thanks
Ken
Thanks
Ken
How about the Audacity Spectrogram track view and Plot Spectrum?
You’ll have to increase the Audacity-spectrogram window-size from the default setting to match the high-resolution of “Raven Viewer”, ( settings are in Audacity preferences , spectrograms) …
[ the increased window size will put extra strain on your computer’s CPU : things may get a bit sluggish ]
Real time? Audacity doesn’t do any effects or tools in real time. Koz
If it brief is “real-time spectrogram” there are free options … https://forum.audacityteam.org/t/filtering-frequency-during-recording/24899/11
