I installed the pre-release 2.1.2 and found a bug. ReaEQ either freezes or crashes when I try to do almost anything in it. I can load a saved setting,but I get a pop-up telling me that I’m loading a setting from a plugin into a standalone. It crashes as soon as I try to apply and no change happens to the track. I have not changed ReaEQ.
ReaEQ crash.zip (140 KB)
Thanks. Added at http://bugzilla.audacityteam.org/show_bug.cgi?id=1279.
Thank you.
A possible fix has been committed now. Testing welcomed. The fix will be available in any Windows Nightly Builds on or after 23 May 2016.
Thank you again.
Fixed. Thank you.
