I use real-time reverb for several tracks, so when I mix all the tracks into a single track, the reverb level is no longer the same. The same problem arises if I do an audio export of all the tracks using real-time reverb.
In Audacity some plugins apply their default settings when you mix-down or export, rather than using your settings. A possible workaround is saving your settings as a preset in the plugin, (not guaranteed to work).
Thank you for your answer
