I’ve read through probably all the posts on this forum about this issue and I still haven’t reach a proper solution. I feel like this used to work.
The issue is, when I go to export a project, the real-time effects don’t render at all. Volume increase and panning works, but anything under Effects is discarded. The effects I’m using are Pro EQ, Delay, Reverb and Master. All part of the MuseFX bundle. Mix and Render doesn’t work either (mono or stereo). Basically the same result as when exporting.
I’m not sure what else I can do short of recording the output from Audacity.
I’ve just uninstalled and reinstalled Audacity. I may revert back to a previous version.
Your post made me realize that I dont trust it! I have taken to saving raw versions of my tracks before applying plug-ins, and then mix and render the individual tracks as the last step before export. And I still am not comfortable applying master level plugins once for all tracks. (I assume that the effects have been applied when I mix and render but the Render doesnt turn off the Master Plug In’s.) I am not sure I even have a real problem with some or all plug-in’s, so I add a couple steps to the flow to feel confident.
