Quick Way to "Solo" Multiple Tracks?
Hello,
I’m using Windows 7 and vers. 2.1.2 of Audacity.
I have a recording session with many tracks. I thought I might start by adjusting just the drums and there are six tracks of drums. Every time I want to work on them I have to click “Solo” on each track. Or is there a faster way to do this?
Same for working with the entire rhythm section.
Or I guess I could mute the tracks I don’t want to hear? That might be faster. So then I tried selecting tracks I didn’t want to hear and chose “Mute all Tracks” but that function ignored the tracks that I selected and muted EVERYTHING.
I just beginning but I’d like to work faster and easier in Audacity and I find this clicking on Mute or Solo buttons kind of tiresome.
pete in oakland
The keyboard shortcuts can sometimes be quicker than using the mouse:
Ctrl+U Mute all tracks.
Shift+Ctrl+U Unmute all tracks.
Shift+S Toggle “solo” on/off for the current track. Use in conjunction with the up/down cursor keys and the “Muli-track” solo button option (see the bottom of this page: http://manual.audacityteam.org/man/tracks_preferences.html#behaviors)
Steve, Do attempt to Shift + toggle while the song is playing or paused?
Is that a question?
“Shift+S” works for me on Audacity 2.1.3 alpha on Linux.
Thank you, Steve for the keyboard shortcuts. Yes, using the up/down keys and Sft-S is SOMEWHAT faster.
Fortunately, the Effects work on all selected tracks. I just wish the Solo function worked this way also.
pete
What would the Solo button do on all selected tracks? Or do you mean a setting that selecting a track automatically soloed it?
Did you enable the “Multi-track” Solo Button Mode? I think you will do better with that mode.
Thank you, Gale, for this though I was a little thrown by your terminology. I guess you meant to select “Standard”, the first choice under Preferences, Tracks, Solo Button. I’m getting more comfortable with the keyboard short cuts to Solo 7 drum tracks and work just on them. Still, wouldn’t be faster to select them and click on a Solo button just once to make them the only active/audible tracks?
pete
I just repeated Steve’s suggestion, but yes in 2.1.2 the choice you want is called “Standard”. In the next 2.1.3 version of Audacity, that option is called “Multi-track”. People involved in Quality Assurance and Development always work with builds using the latest not-yet-released code.
Selecting three tracks then use a command or menu item to solo selected tracks is one more step than clicking three Solo buttons. Is such a command or menu item what you want?
Is what you really want a fourth option for Solo Button “Selected tracks” or some such name, whereby whatever tracks are selected are soloed?
